Okay, I have been reading the posts about the AOS and am a little confused. I have a 2000 C2 tip and was looking for the source of a possible vacuum leak. Decided to take the oil filler cap off and found some significant suction. Also, the car idle became a little rough. Reading posts suggests there should be anywhere from no vacuum to a slight vacuum (not sure how slight "slight" is). I do notice some oil accumulation on the outside of the intake plenum on the drivers side. Also, I have cleaned the throttle body and it was fairly dirty and could see some oily residue inside the plenum. I don't really notice smoke on start up except when it is very cold out (thought that was condensation). Is there a good and correct way to test the AOS?
I have a answer posted in the 996 Carrera forum in connection with your question.
