My pride and joy (1997 Boxster 2.5) played up on me on my way to work yesterday morning. I was driving on the motorway when there was a sudden loss of power. I was able to nurse it to the nearest off-ramp. I was able to crawl at a snails pace with the engine RPM just above idle. Any attempt to accelerate ended up with the engine cutting out. On the way to a nearby garage close to the off-ramp, the CEL started flashing for a short wile and eventually ended up as a full amber. At this point normal engine power was restored and I steadily returned home.
I downloaded the fault codes last night and now need some advice on what the problem may could be. For what I was able to establish searching the forum points towards a faulty MAF. Even though several O2 fault codes appear in the list, am I correct to assume that they only reports the emission issues and that the actual item causing the problem is “upstream”. This leads me to believe that it may be the MAF to blame.
P.S. A problem I’ve also been struggling from time to time is when accelerating the engine briefly “hesitates” going through the 4500 RPM range. This I also considered to be the MAF giving notice.
The fault codes downloaded are listed below.
Eagerly awaiting your responds.
Cheers
Motronic 5.2.2
Current Fault Codes
________________________________________
P1123
Factory Fault Code 27 - Oxygen sensing adaptation range 1 (cylinders 1-3)
Lean limit
P1125
Factory Fault Code 35 - Oxygen sensing adaptation range 1 (cylinders 4-6)
Lean limit
P1531
Factory Fault Code 174 - Camshaft adjustment, bank 1
P1128
Factory Fault Code 26 - Oxygen sensing adaptation range 2 (cylinders 1-3)
Enrichment limit
P1130
Factory Fault Code 34 - Oxygen sensing adaptation range 2 (cylinders 4-6)
Enrichment limit
P1319
Factory Fault Code 62 - Misfire, emission related
P1313
Factory Fault Code 50 - Misfire, cylinder 1, emission related
P1318
Factory Fault Code 55 - Misfire, cylinder 6, emission related
P1314
Factory Fault Code 51 - Misfire, cylinder 2, emission related
P0130
Factory Fault Code 10 - Oxygen sensor ahead of catalytic converter (cylinders 1-3)
Short circuit of wires or limited voltage increase
P0150
Factory Fault Code 18 - Oxygen sensor ahead of catalytic converter (cylinders 4-6)
P0300
Factory Fault Code 75 - Misfire damaging to catalytic converter
P0301
Factory Fault Code 63 - Misfire, cylinder 1, damaging to catalytic converter
P0302
Factory Fault Code 64 - Misfire, cylinder 2, damaging to catalytic converter
P0303
Factory Fault Code 65 - Misfire, cylinder 3, damaging to catalytic converter
P1315
Factory Fault Code 52 - Misfire, cylinder 3, emission related
Copyright 2005-2006. Durametric Software Inc. All rights reserved.
Porsche, Cayenne, Boxster, Cayman, Turbo are registered trademarks of
Dr. Ing. h. c. F. Porsche AG.
Durametric Software is not affiliated with Porsche in any way.
  • 6 months later...
Cheers
Motronic 5.2.2
Current Fault Codes
P1123
Lean limit
P1125
Lean limit
P1531
P1128
Enrichment limit
P1130
Enrichment limit
P1319
P1313
P1318
P1314
P0130
P0150
P0300
P0301
P0302
P0303
P1315
hey my car has the same problem with just about all your codes
did you ever find a solution
my car was running like shi*
then i cleared the codes and wont run at all starts runs super rough then cuts off
