I am trying to find the correct wires that run to the amplifier and CD changer to connect to the RCA outputs on my new receiver. It is a 2002 996 with factory wiring harness unplugged from the factory radio. I have a new Kenwood head unit and need to hook up the RCA preouts to the amp. Anyone know what the correct wires are? Thanks.
:welcome:
Model number on your radio please? (i.e CDR-220, CR-220, etc.)
Also, BOSE (M680) or Harman (M490) amp?
The only information on the actual amp is:
AMP ASSY, 3690, 996 CABRIO
The radio is (was) a Becker BE6625 before it died.
Of note, I read in previous posts that the yellow wire block contained all the pre-out wires and the remote amp turn on wire. Mine contains just one wire, the remote amp turn on. Thanks!!
