The cruise control on my 02 Turbo is not working (meaning, i am not able to activate it / the Cruise light in the cluster does not turn green).
I took it to the dealer in Nashville and was told the issue was the instrument cluster. Not sure if this is accurate or not but at $1800 to replace i want to make sure this is the issue.
are there any other possible causes for this failure?
Thx
Pretty much has to be the stalk, the clutch switch (which would also not let you start the car), or the cluster.
Someone with a PST2 or PIWIS tester can run diagnostics to make sure where the problem lies.
thx!
thx!
OK, so the issue is apparently the cluster. it is apparently an 1800 fix which is really crazy to simply fix the cruise control. i tend to do a lot of longer drives so i would like to have it. Any suggestions other than swallow hard? Thx!
thx!
Might I ask how they confirmed the problem is in the cluster?
Try a reprogram and notification in to the system also before you perform a cluster replacement.
Do you need a brand new clutster, or could someone like Silverstar or Oklahoma Foreign provide you with a cluster out of a car or parts of a car they might have in their inventory???? I've used a number of "recycled" parts in the interest of trying to save some $$$. Maybe this concept is unacceptable....but it has worked for me on a number of occasions. I usually buy the parts I need at 1/3 to 1/2 of the retail cost. Again....your mindset is key to this approach.
I am not opposed to that as long as i can pul the mileage / brains out of my old one. Thx for the advice.
  • 3 years later...
