Is it carbureted or injected.
Sometimes there can be a leak from a carburetor which will run by an open valve and then by the rings into the crankcase.
It's hard for me to remember that far back, but does it have a case mounted fuel pump [which runs off of a cam.]
I have seen those do the same thing, the diaphragm will leak inside the pump leaking into the case.
