I want to remove the inner door panel to work on the inside of the door on my 996. Does anyone know if I need to disconnet the battery when unplugging the airbag connector on the door panel?
To be safe - Yes.
Also, remove the key from the ignition and wait at least 5 minutes after disconnecting the battery.
I removed mine last week. After I removed the battery cable I pushed the Flasher Light switch (of course nothing happened) as a precaution. Someone once told me to do that to make sure the power was all drained off.
