Greetings.
I am preparing my car for spring 2009: C4S Coupe 2004 (10,641 mls)
I changed the oil before storage last October (2008) (Mobil 1 0-40 Syn)
Zero winter starts.
Trickle charged @ 1.5 Amps ("Smart" Charger)
I would like to isolate the spark plugs from the firing sequence prior to starting the engine the first time after 5 month storage. Turning the engine over on battery power ensures oil transits through the critical engine components prior to first engine start; 24 revolutions puts all cylinders through each of the 4 cycles.
What is an easy method of grounding/isolating the spark plugs during the ignition phase while the starter is turning the crank?
Regards,
David
Greetings.
Zero winter starts.
Regards,
David
Remove the fuel pump fuse.
Greetings.
Zero winter starts.
Regards,
David
Yes, but removing the fuse will throw a Cel, right?
Greetings.
Zero winter starts.
Regards,
David
No it won't. And it wouldn't matter if it did.
Removing fuel pump fuse sounds good.
In my documentation all I can find is a fuel relay: Row C - Position 4 (25amp)
I don't think there is a fuel fuse.
I try it, Thanks.
