Hello folks.....,
Please folks don't laugh at me but when you are talking about RMS.....where is located the rear of the engine.I mean i can find once in a while a oil drip on the garage floor and the drip is located closer to the middle of the car then near the rear bumper. Could it be a RMS leaking or if the drip should be near the rear bumper.Is the rear of the engine located face to the rear or to the front of the car.
My car is a 1999 tip with 70K.
Robert
Hello folks.....,
Robert
The rear main seal is at the end of your crankshaft -- and seals the block and and the crankshaft.
But since your engine is actually mid-mounted, and the crankshaft is connected to the flywheel
where the transmission is connected.
If the seal is leaking -- it will show up right about the cross member just forward of the rear wheels.
The rear wheels are connected to the transmission about mid way.
So compare the leak to the location of the rear wheels. Btw, the IMS is in line with the RMS as the
crankshaft sits just above the IMS. So you really can't tell which is leaking until you split the transmission from
the engine.
If you can jack it up -- see where it is coming from along the engine -- you could be "lucky" and just
have a loose or stripped oil plug.
m
Rear of engine is toward the front of the car. Front of engine is staring at you when you lift the engine cover. Do some searching on here and you will find some posts with pics and much, much more information than I am capable of describing.
Hello folks.....,
Robert
