I have a 2006 US spec C2.1 fitted with the standard 55w H7 low beam and 65w H9 high beam halogen bulbs. I want brighter lights but do not want to go to the expense of retrofitting the Xenon setup.
What are the highest wattage halogen bulbs I can use?
I drive with daytime running lights on, i.e. the low beam is on all the time.
I suppose the limiting factors would be alternator output, wiring guage, headlamp housing materials, bulb holder/socket materials?
There are 75w and even 100w bulbs on the market, but I don't want to do any damage to the car or its components by using too high a wattage bulb.
The blue tinted bulbs give off a whiter light (albeit of reduced intensity due to the tinting) and this may be the way to go. Any suggestions?
Gavins:
There is another limiting factor that you have not considered. If you go too high in wattage, you run the risk of melting parts, so be careful!
Do a search here and you may find the cut-off point at which some members experienced melting lenses, etc.
Regards, Maurice.
