Since I bought it last year, my 2002 has never had a smooth shift, especially between 1st and 2nd. It seems to get hung up briefly as it crosses the half way point. It's not as bad between other gears. I had the short shifter installed last year and it made no difference. I realize the short shifter has some issue when cold but this is not a cold issue, it happened before the short shifter and even after the car is warmed up with the short shifter.
I'm bringing it to have it looked at in a week but when I booked the appointment the service tech said it sounds to him like a worn linkage. Anyone else have a similar problem that was fixed by replacing the shifter linkage?
I would try and adjust your linkage first. If you have all original parts and have not replace shifter to a short throw you can purchase the adjuster tool from Sunset.
