I dropped my car off at the body shop for the 997.2 led retrofit install. Does anyone have the wire diagram on what to change to make it work from a 2001 996TT.
I saw that http://www.jacquemond.com/ has already done the conversion on a 996, but he has not responded to my email.
His 997SportLook-09 body program for Porsche 996 3.4 and 3.6 uses a stock 996 body and makes it look like a 997 with the 997.2 led tails
http://www.jacquemond.com/997spl9.htm
I purchased the retrofit kit from Suncoast. They say they know it works for sure on all 997.1, but have no experience with a 996.
Does anyone have a wire diagram of the rear tail light harness on a 996tt 2001 model, and the wire diagram of the LED tail light. That way I can match up the pins.
Also I got a black hella box from Suncoast as well that says its required for 2005-2007 997, for 2007.5-2009 the tail lights plug straight in.
So I am just not sure where that black box goes.
http://e-partssales.com/Merchant2/merchant...Code=9972lights
Edited by iforged
