I have a 5 speed 2008 Boxster limited. It is not as easy to shift as the 6 speed trans. Please advise any suggestions such as modifications, shifting procedure, etc. Thank you, Larry
Edited by Loren
Removed ALL CAPS - please do not post in ALL CAPS -- that is SHOUTING on the Internet
Not sure what you mean by not as easy. Have you compared with another 5 speed or do you only have the one to compare with the 6 speed? We'd need more details to help diagnose why it is not "as easy". It could be a linkage adjustment needed on your shifter. Or I believe our clutches are hydraulic and pull from the brake fluid tank (I'm new to my Boxster...had an Audi TT before that operated this way) so if you have old fluid you may not be getting a clean shift. Or you may just need to bleed some fluid from the clutch if these are in fact hydraulic.
