I noticed while changing my oil that my transfercase fluid is low!!
Anyways i wasnt able to find out what kind or the weight of the fluid.
What do you guys recommend for changing/topping off the transfer case fluid!!!
The correct fluid is available through the dealer though I dont recall exactly what it uses. A quick call and you should be on your way. I'm curious how you deduced it was low and how many miles are on your Cayenne.
