I've got a 1999 Boxster and yesterday I started the car adn the key felt a little different when I started the car. Didn't give it much thought until I stoped and went to turn off the ignition. The key didn't want to stay in the zero position but wanted to spring to the right. I could hold it in the zero position and pull back on the key to remove but once I opened my door, the dinging alarm would go off and some instrument lights stay on like the odometer. Also the buttons on the key doesn't lock the door remotely so you have to use the key and it only locks the drivers side door and not the passenger. I'm hoping I can find some help or ideas on what this might be...one last thing is when you start the car now, the starter can hang because the key isn't returning to the correct position when you release it during starting??
:welcome:
Please give our Search a try next time...
Replacing the Ignition Switch
:welcome:
How do I get the key assembly out of the steering lock assembly?I have everything out of the car I just need to put my key assembly in the new ignition/steering lock..Thank you..
Edited by bjburgett976
