Hi
I need the plug-in couplings for the tubings which connect the hydraulic pressure and return line to the pump. There are two sizes and I need the parts which go to the threads on both flexible lines. Then the male part of the rigid tubes are inserted inside this coupling. On the attached drawing, the part "A" and "C".
Are they a Porsche part, or a commonly available part? I tried the pelican parts, and the price was staggering $134 ea. I hope I was wrong!!!!!
Pls advise...thanks
Kare
Probably not that common, perhaps Audi and VW use the same system in their cars.
