  • 3 months later...
I used the NAV TV version, which is the one that DICE labels as their own. It works well, but I am using a PCM with Nav. I'm not sure if it will work on your unit. If the compatibility charts list yours, then you should be Ok.
I have a 2006 997 without nav. has anyone installed the dice unit to power up an ipod touch. any negatives. thanks, tom
