I have all the wiring in place in my 99 Boxster for the CD multichanger but i was wondering if it had to be the original Porsche one which was fitted?
Could I buy a generic one and fit it?
My head unit is the standard CDR23
Interesting... I don't recall the CDR23 system being intro'd until the '03-'04 Boxsters (w/ the MOST system, bu tI could be wrong). I thought the common h/u for '99 was either the CR/CDR-210 or 220. With those, I recall reading somewhere along the way the CD changer was just a rebranded Sony unit... or at least there was a generic Sony unit which would work (only the 6 disc version not the 10 disc though). Try a search in the archives on Sony 6 disc changer or some variation and you should find your answer. Good luck!
PS- I see you are from the UK so that might change things entirely...
Edited by Cassiebox
In RoW cars the radios for up MY03 would have been CR-22 as well as CDR-32.
So perhaps the original poster has a CDR-32 (more or less equal to a CDR-220).
I would suggest, if you have an i-pod, Zune or other mp3 player, that you will be much happier installing the adapter cable for it and the mp3 player instead of the cd-changer. To date, I have about half my audio library on a Zune connected to the aux cable for the CDR-220. I just set it on shuffle and have around 2000 songs in almost any rotation i want. It is like having your own radio station. It give you many more options of cds or songs to listen to 6+1 CD vs 200 CDs or more. It is also less expensive ($25 US) than tracking down a previously used CD changer (maybe $200US.) Also, you don't have to go into the front trunk to change discs. The quality of sound is comparable to having a CD playing.
Would you tell me more about this adapter cable? I have Creative Zen Vision:M and iAudio X5 MP3 players.
I've posted a thread over on RL http://forums.rennlist.com/rennforums/996-...ger-in-gt3.html looking for info on CD changer, XM radio (I understand the Cayenne unit will do this), and connectivity to an MP3 player. I also posted here over on the GT3 forum.
I was about to order the FM modulator recommended in that thread http://www.crutchfield.com/p_142FMMOD02/Sc...tor&tp=1287. Is what you're talking about the same sort of thing? If not, can you amplify, please?
BTW, I have the CDR23 in my car.
Edited by ltcjmramos
