My car is a 2008 Boxster S, I'm currently trying to install a carbon fiber light surround piece, which is located right beside the ignition. My first obstacle is getting the light switch out from the surrond housing unit, so that I can access the screws that hold it in place. I've removed the side panels from the dash for some visibility of the switch unit. I can put 2 fingers through the side hole and push on the switch, but it doesn't seem to want to budge out. Any suggestions in what to do next. There must be a step i'm missing? Thank-you
