Had a whack of codes in my 1997 Boxter pointing to Varia cam problem.
Changed Varia Cam solenoid bank 1 and resealed cam cover in car.
Car runs better, however when I checked for codes after a short drive I got
P1319-misfire emmision relevant
P1313-misfire cylinder 1 emission relevant
P1314-misfire cylinder 2 emission relevant
P1315-misfire cylinder 3 emission relevant
P0341- camshaft position sensor 1
CEL light not on, but may be I did not drive it far enough (car not licensed yet)
Car idles rougher as it warms up. I did not change sparkplugs yet as I wanted to solve Varia Cam problem first.
Before changing Varia Cam solenoid I have switched Camshaft position sensors from Bank 1 to 2 and still have PO341. I have ohmed out wiring for Camshaft sensor to ecm and it is ok.
I cleared codes and ran again and now have all the same codes but PO130 has come up...o2 sensor ahead of cat.
After changing variacam is there a reset procedure? Other than clearing codes or disconnecting battery?
Wiring for Varia Cam solenoid was checked to ecm before I bought new solenoid.
Could all these problems be the o2 sensor? Need input as I am stumped>>>
P1313 Misfire, Cylinder 1, Emission Relevant
P1314 Misfire, Cylinder 2, Emission Relevant
P1315 Misfire, Cylinder 3, Emission Relevant
P1319 Misfire, Emission Relevant
Potential causes:
- Fouled, faulty or incorrect
- Contact resistance
- Loose contacts
Check you coil packs and electrical connectors on them.
P0341 Camshaft Position Sensor 1 - Signal Implausible, Short to Ground, Short to B+
Potential causes:
- No power supply.
- Short circuit to B+.
- Short circuit to ground.
- CMP sensor faulty
Best check the wiring again.
Thanks Loren,
When I re-installed the coils after doing the Varia Cam they did not seem to snap onto the spark plugs..
Plugs are not fouled, but may be incorrect..I will check again.
I inadventantly got the wiring for coil #3 caught in the cover and had to repair the harness after installing cam cover. But is is soldered and heat shrunk.
For PO341 I have checked the wiring as per my Bentley manual
It is called Hall sensor #1 in Bentley.
Re/VI on plug ohmed ok to pin 53 of ecm. (5v supply)
Re/GR on plug ohmed ok to pin 21 of ecm. (hall sensor signal)
Br/PK on plug ohmed ok to pin 34 of ecm. (ground sensors)
I did not ohm any of the pins to ground.... what is B+?
Is CMP sensor the Camshaft Position Sensor?
Thanks..
Should be +5 VDC between pin 1 and pin 3.
Yes.
The signal from CMP sensor 1 identifies the first cylinder. If both the crankshaft position (reference mark) signal and the CMP sensor signal coincide, this signifies the ignition timing for cylinder 1. The recognition of cylinder 1 is necessary for the purpose of sequential fuel injection and knock sensing.
I checked Pins 1-3 wih key on and sensor unplugged it has 4.98v.
Sensor was swapped from left bank a few weeks ago. I believe it is good as no error code on left side...
Also checked pin 2 to ground and it is open...what's next?
Pulled 1-3 plugs and they are now fouled. Checked coil extentions that pull off coils and no continuity on them.
Plugs are bosch FR6?...I thought they should be FR7?
Ok will check.
What about CMP?
Potential causes:
- No power supply.---------------got power
- Short circuit to B+.-------------no short detected
- Short circuit to ground.-------- no short to ground
- CMP sensor faulty
I guess CMP is faulty? Even though I switched it from left bank and it was not causing error codes on left side?
Clear your fault codes and report back the new fault codes.
Ok, I ordered new plugs and 3 new coils from Sunset. Changed bank 1 plugs and installed new coils.
Cleared codes. Drove car about 3-4 miles. No CEL light on. Checked codes with my code reader... Had PO341 only. Cleared codes...
Put license on off my other car and drove about 15-20 miles up to 120km per hour.
Car has way more power...
No CEL light, but checked codes anyway. Still have
Wiring checks out ok, have 4.98v at pin 1-3 on Camshaft sensor plug. Center wire is not shorted to ground.
Camshaft Sensor is swapped from left bank and thought to be good.
Varia Cam appears to be working as I can feel it at about 5200rpm (feels like a 4 barrel carb opening)
Could the magnet for sensor have fallen off the camshaft? Or lost it's magnetism? Now I am really guessing...
Idle is a bit rough, but better than before.
If I did not have an OBD II reader I would assume all is well as no CEL light on...
