My clutch started making noise a few weeks ago and now it stopped, but the clutch feels like it comes up quicker than before. It has a bit vibration that it never had before, but otherwise the clutch works well. I'm thinking about replacing the clutch spring and see if it helps before i will look into replacing the clutch and flywheel. Is there instructions to do that? I tried to look in the DIY, but no luck.
Has anybody done this before?
kristian
The part number is 996.423.081.11
Edited by kristian
Member greerj1 gives already the solution as an answer to your post dated 2nd march.
I'm actually just looking for a Clutch Power Spring (hydraulic pump) DIY at first, before I do the clutch and flywheel. I just bought the part from the internet and I don't even know where the part is to start with. Trying out a cheap solution first.
Kristian
The assist unit showed in your pic. is located approx. half way to the top of the clutch pedal.
Many iof us have removed the asist spring to obtain better control of the cluch. A single pin holds it to the bracket above the pedal. Make sure you install a nail or cotter pin in the hole in the spring piston that sticks out of the housing BEFORE removing or the spring will pop out.
Thanks Guys
Kristian
