Did you do anything to cause this?
I'd pull out the stereo, re-attach all cables and connectors and make sure they are snug.
If you have a seperate amp, I'd look there for the problem. If you use the head unit, it may be internal (amp section).
But check for loose connectors first.
nope, just parked the car, and when i restarted it, it was making the noise
and then, this morning, everything is fine
aloha
steve
  • 2 months later...
Do you still have the problem?
What year is your Boxster?
Have similar problem with 04 S with fiber optic cable. The dealer when adding Cd changer cut the cable and tried to fix with tape. Does not well.
If you have fiber optic cable connecting your unit then look to the cable and or connectors.
