Good morning,
Looking to replace my old worn out 2006 Cayenne S Titanium Edition key & key fob.
Could you please let me know the part#?
Thanks in advance!
Mike
Good morning,
Thanks in advance!
Mike
Need to know what options (I5D2, I4F6, I4K0, etc. etc.) you have and your location for proper frequency.
Also, do you want a blank or precut key (requires lock number)?
Good morning,
Thanks in advance!
Mike
Thanks for the info, not sure about those options... didn't know it would require that much of info to purchase a non-programmed key, always thought the key fob is being shared by MY as default but differentiated based on the options, when it's being programmed.
I'm located in Seattle WA, USA.
Where is lock # located, the bunch of #s hiding behind the key blade?
Thanks again!
Mike
I saw this item on ebay, showing the part# as shown on the picture.
I guess this might not work with MY 2006 Cayenne.
The parts list show that key part number is only good for MY to 2005. And, that is a blank key.
We know your car is US so that makes it 315 MHz (I5D2).
955.637.245.02.01C is a blank key for MY06 and will likely work -- US MSRP $128.25
You will also need 000.0432.06.19 Roll pin -- US MSRP $1.17
