Just wondering if the camber adjustment is limited to the small cam adjustments located on my lower trailing arm, 99 C2. Also, the manual says to adjust just the (B) bolt cam, and not the (A) bolt cam. Seems to me they should be adjusted together to keep the wheel and tire tow the same. By the way, I bought the car lowered and I don't think it was done correctly.
Thanks, Eric
Edited by Eric
