I've ordered a new thicker TechEquipment steering wheel and a new airbag since my buttons are scratched. Does anyone have detailed instructions on how to remove and re-install the steering wheel and airbag? I've found the instruction below, but was hoping for something more detailed.
Any help would be greatly appreciated.
matt
Retract the steering column too the max.
Turn the steering wheel 90° too the left
Insert a flat screwdriver in too the hole on the back of the steering wheel till he hooked after a steel spring
Push the screwdriver in the direction of the steering column, while pulling on the airbag module
Turn the steering wheel 180° to the right and do the same handling in the other hole
Remove the airbag module and the connectors
Remove the center bolt in the steering wheel
Remove the steering wheel
