Hello, I have a 1999 Carrera and I was wondering if a navigation unit from a 2001 Boxster will fit in the 1999 Carrera? Thank you
If your MY99 Carrera already had PCM then it would not be a big deal.
If it does not, then you are looking at a major job of wiring (and cost) for the new system. If this is your case I would suggest a 3rd party navigation system.
Many have been discussed and implemented here - please do a search.
Thanks Loren, sounds like alot of work and time.
