So what is the proper jacking procedure for a Cayenne with a floor jack and 4 jack stands? I see in the rear I can use the differential on the floor jack, but the jacking location in front of the rear wheels has stupid inserts I have to make wood blocks for that are too narrow for jackstands, even the dealer has crushed the inserts using their post jacks.
In the front there isn't a central jacking point and I don't like the flexing that happens when jacking one side of the frame by the wheel as the other wheel even leaves the ground. I saw some threads about jacking one side of the car, but that seem to applies to the cars as when trying that with the Cayenne the opposite front/rear wheel didn't lift high enough before I quit bcuz of the flexing.
