I'd like to change spark plugs on a new to me 2003 Boxster with almosst 70K on it. What would be a good recommended spark plug and what is the proper gap? Also, I have seen people talk about replacing the o rings and tubes. Is this something I should have on hand "just in case"? I don't want to strand myself if God forbid I need parts since this is my daily driver.
I also need new brake pads all the way around. Mine were just barely good enough to pass state safety inspection so I woul dlike to tackle them before the sensors need replacing. I would like some feedback on a pad that will put out as little dust as possible while maintaining street driveability. Can I assume that ceramic pads would be too aggressive for street use?
I appreciate any feedback!
See the 996 change instruction - the process is the same except the plugs are easier to get to.
Spark Plug Change Instructions
MY2003 M96 engines would not be allowed to have tubes and O-rings.
