I've got a 2000 C2 with 110k miles on it. The steering rack has shown some leak on the right side for some time. I've just been adding fluid to it. Today I jacked the car up on that side and when grabbing the wheel at the 3 and 9 position I could rock the wheel back and forth just slightly. If I push a little more then I could see the steering wheel moving. When I grab it at 12 and 6 I don't get any rock. So I assume it is the steering rack or tie rods since I think I have ruled out the wheel bearing. With the rack continually leaking I assume something is letting go. Has anyone replaced one of these before? I have seen that Sunset sells a reman unit. Not sure if I have the time to do this though as it is my daily driver. Any help would be appreciated.
Thanks Renntech
