I have owned my MY98 Boxster since Aug 08 and every time I run the car, I get bits and pieces of black foam rubber out of the vents. I checked the Enviro filter and all looks good there. Any ideas on what it is I'm chasing?
i have the same problem, nthing major but a bit annoyinh when i put the ac on
hope someone knows a solution or what is causing this.
The foam comes off from the airco/heating unit's air mix flap, you can provide some air mix problems in a later stage.
There is a topic on this board somewhere (986/996), i cant find it for the moment, well documented with pics etc. solution inclusive.
Thanks much. I'll start searching.
Good luck....5 hours for me....if I had to do it again...I can do it in 2 -3. You won't trim any time for the 1st time. Major difference after....
  • 2 years later...
  On 3/8/2009 at 3:58 PM, palmtree907 said:
Ok, after about 10 miutes, I found the post and here is a link to the site that had the fix. I'm gonna see if I can trim the 3 hours down a little. Wish me luck.
http://www.carboncow.net
Sorry, but am I missing something? The url is a family album ;) Sorry, if I am being dense.
  • 2 years later...
