Does anyone know possible cause of this fault? Search came up empty. Thanks.
:welcome:
P1505 Throttle Jacking Unit, Control Range – Open Circuit
The throttle angle demanded by the DME control module is achieved by means of a digitial position controller. The rapid and precise setting of the desired throttle position is of major importance for the quality of charging control. If a control range fault occurs, the actuator current for the throttle drive motor exceeds or falls below the nominal value.
Check the connections - reset the fault code and see if it comes back.
:welcome:
Thank you Loren, you are truly a Saint. Sorry for the lack of intro, will get more info once I get her running straight. Bloody supercharger has just been nothing but endless trouble.
I got this fault after cleaning the throttle body with electrical cnotact cleaner. I also got P1508, which maybe to due to another blown MAF (don't know why the evo kit uses the K&N filter.)
Which contacts should I be checking?
Thanks again.
:welcome:
Thanks again.
P1508 Torque Comparison Function Monitor – Signal Implausible
DME control fault.
There are only two connectors on the throttle body - one is throttle position sensor(smaller of the two) and the throttle jacking (the large one).
Inspect and clean the connectors on both and check the wiring for damage.
