I'd check the dipstick before you consider draining any oil. Follow the directions in your OM for the procedure. I doubt 0.3 of a quart is anything to fret over, but check to make sure.
Wow. 4 hours later and it appears to be a quart or more low. What the heck? If you drained all the fluids and installed close the factory spe amount of fluid - how can it be low?
