Hello all,
Need some suggestions/help here...
I have a 2005 Cayenne S, and will not drive it for more two months. Should I disconnect the battery? If so, should it be the driver seat battery, or the trunk battery? Or both??
Many thanks for your advice.
Andy
Would it not be better to use a battery maintainer, no problems, no work, no waste of time. Just an idea, if not, disconnect both battery's ( if the car got 2 battery's) Disconnect the ground lead in front, right of the drivers seat for battery 1 and the ground battery cable in the spare wheel room for battery 2.
My experience with Cayennes is that disconnecting the battery is bad. I'd keep it on a charger/maintainer, or just leave it. It should be OK for 2 months.
I use the Porsche battery maintainer all the time. During winter storage and in between weekend drives.
I would not want the battery disconnected, because this would also disable the alarm. Not a huge concern, but a dis-service and irresponsible, IMHO.
