Hi:
Driver side seat heater switch when pushed blinks red but does not stay on. After reading posts, I replaced relay under seat, but didn't try swapping switch from passenger side. When I contacted the Porsche dealer that sells parts to forum members, they said he spoke to tech & sounded more like heater element is shorting out & drawing too much current. Before I take to a dealer to repair, has anyone experienced this, and if so would you recommend replacing switch first before going to dealer? Thanks in advance, Fred
Defecting heating elements are more common than switches, especially the bottom part of the seat. You can check with a multimeter for short or interruption, the connectors are under the seat (2 wire connectors) for the bottom part and the backrest as well.
Cushions are fairly easy to replace and not that expensive. A reasonable DIY. If you are interested check out Dennisvogel.com and look at his article on adding seat heaters to his Boxster. It has good infor and pictures, i used it as a guide to add heated seats to my 996 Cab and the cushions was aone of the easier parts to do.
