car: 04 Cayenne S with 110K/km
it just happed suddently today on hwy, the "check coolant level" warning is on while driving on hwy,
i looked at oil tem and water tem, they are right in the middle as usual, then i drove about 10min to a Mr.Lube
the reservor is empty already, i can see coolant driping from the under panel, and wind blowed them all over,
they refilled to the max level, then i drove about 15min back to home.
I throught it was the radiator, but i smell burned coolant, and driping seems stoped or slower when i shut the car off
could it be the hose ? or water pump ? could the engine alreday been damaged ?
Edited by lovesolar
Thank you loren
Ive already did some search here, found all are very helpfull !
I have changed oil and plugs before based on peoples instructions here.
Just want to make sure its a bad pipe, then i can follow the instrcution here to replace it without giving lots $ to the dealer.
Hey Bro,
Could be a water pump too, had similar symptoms and I had over an 1" of lateral movement in it.
Cheers
Thank you loren
