My clutch pedal is squeaking again. The dealer lubed it and fixed it for 2-3 months last time, but it's not worth going there just for this. What lube can I use and where/how should I apply it?
(This is an 03 996)
(This is an 03 996)
On the older cars (MY99-01) they used a silicon spray right at the shaft that enters the master cylinder. Do not use oil based lubricants that can damage the master cylinder seals.
(This is an 03 996)
I would also like to know. I have a 2002 911 and haven't been successful silencing my clutch pedal squeaks.
b-man
(This is an 03 996)
Loren, do you have a pic and/or diagram that shows the area you are describing? I don't know what the parts are you named. :huh:
