hi would there be any adverse affects if i put a car cover on my car while the engine is still hot? do i have to wait for it to cool down before putting one on? thanks.
On the TT I always wait because the fan, to cool the engine compartment, can start at any moment if the engine bay reach about 172F. And this protection is available for maximum 40 minutes even if the car keys are in your pocket... What I do I put the cover on and leave the aft section on the roof un til I can touch the exhjaust system with my bare hand...
Edited by jpflip
Oh ok so i just cover like half the car, then wait for it to cool down, then put the rest on?
And i didn't get "172F. And this protection is available for maximum 40 minutes even if the car keys are in your pocke" what does that mean? Thank you for ur response!
This text is taken from Adrian Streather book called "Porsche 996 the essential companion". The bible, I love it...I will used his word because of my french thinking....
The engine overheat after shut-down protection system is activated for a maximum of 40 minutes after the ignition is turned off , and if the engine bay temperature is greater than 25C (77F) . If the engine bay temperature rises to or is already at a temperature in excess of 78C (172F) for more than 3 minutes the engine bay purge fan will be activated. The purge fan will stay running until the engine bay temperature drops below 78C (172F).
engine bay temp higher than 77F system activated and waiting ( in standby and monitoring for 40 minutes)
over 172F for more than 3 minutes fan start
below 172F fan stopped....
It is good to read it again and again It finally make sense ;-)
