I bought a 04 Cayenne tt with 60k miles on it, and one thing I notice is the turbo boost gauge only will reach 0.6. is this normal?
Push the skinny pedal harder. :D
Seriously though, turn off PSM and try again. Can you feel the boost on acceleration? The vehicle should surge in power after an upshift from high RPM.
Flash the computer with the "chip" firmware and you will get the missing boost of Turbo S... up to 1.2Bar (17.40 psi)... although I have not dyno'ed it..
They send you a slave programmer cable you hook up to your laptop and you run some software and apply a firmware tuning file...
There are plenty out there... I got mine from Oliver at www.SpeedTuningUSA.com... works great.
