I sent in to my mechanic today and found some leakage dried up below the water pump area.
Under the TSB "Coolant Pump Replaced Unnecessarily" , my leakage fits exactly the first diagram diagram where the area of leakage doesn't warrant a replacement. The affected area is all dried up and has no sign of moisture. However I am particular sceptical of the condition of the water pump since my car is coming to 3 years old , done 33,000km and my coolant needs to top up more regularly now.
Has anyone's pumps failed earlier than my car?
Does anyone has any link on the DIY on removing the pump? (996 has one but not similar)
(My car warranty is almost due to expire too)
