(2003 996 Coupe) So hear is a good one, I have been working on cars for all of my life. When I get on the car hard either from a stop or while in second gear, the windshield wiper will come on, only as a single pass. If I corner left hard it does the same thing. It must be a loose connector or something along that line. Has anyone had the same problem, if so could someone point me in the right direction of where to start searching?
I appreciate any help,
:o
Mine did this toowhen coming out of a near spin... but in SLOW-MO action replay it was discovered that my hand likes to hit that lever when I get excited...(found after several more times) I had to change a couple minor things with the nut behind the wheel to fix that one!!
GL with the issue
