Not so sure but it seems that there's light shining from within my left interior door handle. However the right handle doesn't illuminate.
Is there really a bulb within? Any idea how do I remove the door panel and also replacing the bulb?
There is a light in there. It's there to illuminate the keyhole and headlight switchgear. It's an LED, so it probably won't burn out.
i can only see a little hole behind the handle and no light at all (despite tuning up to 100%). Is the bulb actually visible or is it hidden behind the hole? i'm wonderng if this is either an extra which i don't have or if the leds have disappeared into the doors. can't see anything on either side (but the window switches light up fine).
ay ideas or are they so feeble that you can't really see them at all?
