Installed OEM XM kit but I cannot get any input of it on PCM. I have tried all 3 of the available orange Fiber optic cables.
Anyone have some possible remedies?
What version software is your PCM? In order to run the OEM Cayenne kit (which is what it sounds like you've done) you need to have at least Model Level B software. If that's up to date and you've otherwise done the install correctly you may need to head to the dealer to have your MOST ring correctly setup.
Edited by PTEC
It is all up and running now.
It turns out with my newly installed basic PCM 2.1, MOST was not activated. No need for it. Dealer tech activated it and it discovered new XM unit. Finally after weeks of missteps, it all works. I am really pleased with it all.
