Hello Everyone:
I have a 2001 Carrera 4 Tiptronic with 63,000 miles.
I recently purchased a Durametric code reader and a flash upgrade cable and software from a well known Porsche tuning company.
Two days ago I loaded the software which automatically reads out the DME software and sends it off to be updated. Yesterday, I received back the updated file together with my original (you are supposed to be able to swap back and forth at will) and then attempted to upgrade the DME.
I followed all of the instructions including attaching a battery charger during the install. I used the Porsche Tequipment (Cytek) charger. The install seemed to work fine but when I tried to start the car, nothing happened.
All of the dash lights come on, central locking, windows, radio, climate control all work, just no starter action.
I checked the codes with the Durametric tool and I get:
Motronic - "DME Failed to Initialize"
Alarm - Fault Code 21 - W Lead (DME Immobilizer)
Airbag - Fault Code 5522- CAN Message Missing
Tiprtonic - Fault Code 0600 - CAN Timeout
Also, when I try to either reload the updated software or load the original file, I get an error message saying "incorrect security access".
I have contacted the tuner and they don't really know what the problem is. They are sending me a new pre-programmed DME from Europe so the car will be out of commission for a few days.
That said, I would appreciate any thoughts you might have on this and whether there might not be a simple fix.
I tried some of the things I have seen from the other alarm/immobilizer/ignition switch threads such as jiggling the key, removing the positive battery connection and reconnecting, and checking to see if "P" correctly shows on the dash.
Finally, I have not had any previous starting or electrical issues.
Thanks in advance.
Scott
I would not worry you but most of this history's ended up with a blown DME. Lucky you get a new one.
You may have inadvertantly cleared the security codes. Only a Porsche dealer can re install those codes. If you have a good relationship with a dealership nearby you may be able to get them to come to you and reset the codes. This happened to my car when my engine conversion was done.
Not saying that this is the problem but it's a possibility.
Hopefully your new DME will be the fix.
Good luck!
Edited by phillipj
All:
Thank you for the responses. I guess I will wait for the new DME and update you all next week.
Regards,
Scott
If you can find someone with a PST2 or PIWIS you could try to re-program the DME back to stock.
But with either solution you will need the car's IPAS security codes.
All:
Regards,
Scott
He is a little to far from me :)
Hi all:
Well it turned out to be something with the DME. I received the new one today, popped it in and the car started right up.
Thanks again for sharing your thoughts.
Regards,
Scott
Brad,
They don't have it yet, but they will. They asked for the old DME so that they can figure out what went wrong. I will ask them to let me know if they can determine the cause of the error once they have a chance to assess the old DME.
I have been dealing with FVD Brombacher and I have to say it has been one of the best customer support experiences I have ever had. Communication has been quick and friendly. As the source of the error could not be located from the info I was providing, they quickly decided to procure a preprogrammed DME from the headquarters using the file I originally sent them and had it express mailed to me directly from Germany.
I was given clear instructions on how to do the install and the technician gave me his personal cell phone and said I could call if I got into trouble even though FVD USA is in Florida and I am on Seattle. Heck, the tech called me tonight at 8:30 PM his time to see if everything worked out ok.
Thankfully it did work out and he told me how to retrain the throttle programming.
Notwithstanding the original issue, which could have been my DME rather than any issue on the FVD side, the whole experience has been great. They could have called me an idiot and told me it was user error, but instead went to the complete other extreme.
Scott, that's great to hear. I recently made my first purchase with FVD here in the US (spacers), and they were great to deal with.
Well, I have not had a lot of drive time to really test it out, but on the few drives I have had so far I can validate that the throttle response is definitely quicker. This may not be the most scientific description but the car seems much more eager, like it is always poised to really take off. The downshifts also seem to happen more quickly and more readily with only slight throttle input.
All in all, I was thinking on the commute home this evening that this is more like how I expected the car to be. Many of the descriptions in the press talk about how the 911 is docile around town but screams when you want it to. The remapping seems to have brought the low speed around town response one step toward the screaming end of the spectrum but without it feeling harsh or choppy.
I will provide a further update once I have had a chance for some longer drives.
As an aside, this is my second FVD purchase. I also bought a carbon/leather steering wheel with paddle shifters from them. I didn't have need of the same level of support, but the overall experience on that purchase was also very positive. For those with Tips, it is a mod I highly recommend. I, for one, could never get used to the rocker buttons.
