Haven't checked the codes in my car for a while but checked it with my Durametric today and found this :
P0160
Porsche fault code 20 - O2 sensor behind CAT.conv.
Bank 2
Car has been running fine and still does but has had a little occasional misfire on idle when warm??????
Could this of been the cause?????
Whats best course of action ? Replace sensor ?
Any tests?
Just to add
The occasional misfire was on cylinder 5 which I believe is bank 2.
Plug and coil was changed but made no difference
Not likely related to the misfire.
P0160 20 Oxygen Sensor After TWC, Bank 2 – Open Circuit
Possible fault cause
- Open circuit in signal wire or ground wire of oxygen sensor
- Oxygen sensor heating faulty
Check the wiring connector for breaks or corrosion.
Check resistance between pin 1 and 2 towards the oxygen sensor - should be 9 to 10 ohms at 10 degrees C.
If the wiring is good then replace the sensor.
With the Durametric software, what boxes shall I tick so it can monitor what the sensor is doing and log it.
There's lots of boxes and I'm not sure what ones I need to look at
Done some datalogging and found this. Appears the 02 sensor on bank 2 has no resistance? Does this confirm its faulty?
O2 sensor resistance behind cat bank 1 = 0.99 to 1.00
O2 sensor voltage behind cat bank 1 = 0.88 to 0.89
O2 sensor resistance behind cat bank 2 = 0 to 0
O2 sensor voltage behind cat bank 2 = 0.69 to 0.74
Edited by andymac
