I am looking for the Center Tail Light delete which I am told was used on the MKII Aerokit since the MKII wing had this light in the wing. I have a MKI aero and have removed the fan which has disabled the light. I could paint the light black but would like to put in the blank piece made to fit the place where the light resides. Thanks.
The only blank piece that I know of is for the Carrera Wing used on Cabriolets. In this case it replaces the light lens in the rear window.
I do not know if that will work for you but here is the part number.
996.504.980.00 Cover; primered; material: ABS (for brake light under rear window) with Porsche logo. I do not know if it is still available.
Thanks Loren. I will see where that leads.
