I have a 6 disc CD changer in the trunk of the 996 C4, lately it's been pausing/skipping music
over bumps. Does anyone know if there is a fix to this problem? JC
First what type of CDs are you using (self burned). Are they scratched? Things I would try...first make sure it is secure, then run a cd cleaner disk.
I've tried a CD cleaner & skipping happens both with factory & burned CDs. Are there any joints to oil?
If you're using blank CD's you've burned yourself the problem may be the brand of CD's. This problem happened to me using CompUSA blanks.
When I changed to Phillips no more pause/skipping. I think any name brand will do better than private label stuff.
Did what you suggested & CD still pausing over bumps. Any other tricks you've tried? JC
Will look for phillips, not always to find particular brands in the islands. B)
Would it be that the CD reader is defective?
