No, not without some work. I looked into it as well, as I like them better than the 996 mirrors. The electrical connectors are different, as well as the mounting holes. The angles of the outside trim appear to be the same, so from an exterior cosmetic view, they should work. If cost were no object, and there was access to a body shop that did nice custom work, it would be do-able, though.
