I have seen the DIY threads for performing the amberectomy, I do want to double check this:
• The piece that gets removed, as seen below (borrowed from Toolpants thread), which would be amber in my case, is just wedged in place, it's not glued in, correct??
• Is Xenonmods.com a good place to get the silver bulbs?
I am thinking going the Dremel-with-the-wand route, attaching a small rubber hose to a vacumm to clean up afterwards.
Alex
Edited by londoner06
Alex,
You are correct. The angle piece in the picture (amber) is what you want to remove and it is not glued. It's pretty easy to remove. I used a pair of needle nose pliers and a hot scalpel to break apart the plastic. The dremmel with the wand approach should work nicely. As far as the bulbs. I got lucky and found a set of silver bulbs at autozone. You may be able to pick up a set of clear LEDs that light up amber.
Ken
Edited by Hobbes
