I just changed my clutch and was dreading that I had damaged the flywheel and would have to replace it. . . Luckily, It wasn't that bad at all!!!
I ended up using a die grinder with a 50 or 80 grit surface prep disc from northern tool. Took about twenty minutes and I was quite happy with the results.
Some pics for your viewing pleasure.
Regards,
JP Hooie
:renntech:
