Recently, when braking firmly and the tank is at least 1/2 full there is occasionally a smell of gasoline that enters the cabin. I've tried to determine if it's also noticeable externally but am unable to tell as it may dissipate too quickly.
Seems like it's probably a bad valve or hose but not sure which is the most likely culprit.
You might want to remove the battery and check underneath it (where the fuel tank is). Sometime critters like to crawl in there and nibble on the wires and hoses.
If it is that noticeable I am surprised you don't have a CEL.
