Can anyone tell me if the center section on the Aerokit front bumper is open or closed as compared to the GT-3 bumper. The two openings on either side (the openings in front of the raditators appear to be identical) however I believe the "opening" on the Aerokit front bumper is closed.... using the plastic insert from the OEM bumper whereas the GT-3 bumper is completely open in the center section. Thanks for any information you can share.
Thanks Loren...no third radiator as the car is a 997 C4S. So I think I have my answer that I use the cover from the OEM bumper on the Aerokit bumper....if I don't the opening looks unfinished as it is made for something to go into it. Is there a part number for just the frame for that center section like the frames that go into either end of the bumper cover? Not sure it matters as there is no 3rd radiator but was thinking if I wanted to do the mesh grills a frame for the middle section may make it look better or even allow the middle grill to be installed. Thanks for the quick response!
